this is a 2004 accent diesel , using the scan tool I get bad camshaft sensor malfunctioning and using the multimeter I got those readings on its terminal ( same connected or not ) 0V , 5V , 12V.
the car doesn't start , tried to force the 5v signal to ground to see if the injection working with it but it didn't but in case I start the car by towing or by injecting some gas to the intake while cranking it starts and keeps running I replaced the sensor but got the same results
what could be the fault here ? ( is the wiring correct ?)
