I completely rebuilt my truck engine, the only thing I didn't do was take the block out. But I replaced all the gaskets and piston rings. Took it apart and reassembled down to a bolt. Then I drove it 45 mi and the CEL turned on. Got home and plugged the OBD2 to read P0101 -- mass air flow. One thing I did not do was replace the air filter because it looked pretty clean.
How can I go about pinpointing what the cause of this code is? I understand what it means is that the engine is not absorbing the expected volume of air but the causes can be different, such as leaky intake manifold gaskets, which I replaced. Could the sensor itself be broken and need replacement?
Yes, the sensor is most likely your problem. Try cleaning your MAF sensor. Use only cleaning solution specified for cleaning the MAF. It is a delicate thing, so be careful with it. If that doesn't work, try exchanging your MAF with a known good one. If that works, you need a new one.
13
  • so basically, if cleaning the sensor does not clear the code, buy a new sensor, correct?
    – amphibient
    Dec 8, 2022 at 23:47
  • I found this useful video: youtube.com/watch?v=gRfaPfTcfOM
    – amphibient
    Dec 9, 2022 at 0:01
    @amphibient - Before you buy a new sensor, see if you can find a "donor" from some other vehicle to check. Before you buy anything, always know that what you're purchasing is actually needed. A new MAF may not be the ticket, but it sure looks like it from here. Dec 9, 2022 at 2:08
  • yeah, makes sense, except I don't know any "donor". I just cleaned the MAF sensor with the special spray and also replaced the air filter, which did look kinda bad on a second look
    – amphibient
    Dec 9, 2022 at 3:29
  • Use an OBD reader to read the live values from the MAF. You should be able to get it to draw a live graph. Check if the graph looks something like expected.
    – HandyHowie
    Dec 9, 2022 at 8:57
