My Volvo recently had a generator issue that caused it to drain its battery completely (as in: not even power to the dashboard). After having a garage replace the generator and test and charge the battery, things are back to normal - almost.
The power windows have that sort of two-step switches that allow you to roll down the window for a bit while you're activating the button, or you can lift/depress the button entirely and the window will go fully up/down. It's this latter feature that no longer functions. Is there anything I can do to fix this that doesn't involve a costly trip to a garage?
I've previously had problems with the automatic start/stop function which was resolved by switching to a better battery. This feature still works so I'm guessing the battery is okay and it's perhaps a configuration issue that I don't have a user interface for. There are user settings for "triple indicator" and "turning headlights" but obviously a ton of features don't have (user facing) configurable settings.
