I can't jump start my Volvo V70 as my boot is locked.I have been told that I can jumpstart it on the engine ,but where? Battery is in the boot..it's a bifuel estate.
Here is where the jump points are for your V70:
Positive jump point is located behind the fuse box by the strut tower:
The negative jump point is located to the right side of the engine (as if sitting in the driver's seat) where you can see the clamp on the metal loop:
Attache them in this order (per Volvo):
