Here is my problem.
The engine starts normally, but when I'm driving, starts do heavy jerks (shakes). It doesn't matter in which gear. The point is that it only happens when it is moving, but if I'm in neutral or pressing the clutch, the rpm goes up normally. Maybe not 100% smooth, but without any jerks.
I've already changed.
- Sparks
- Distributor cap
- Fuel filter
- Distribuitor rotor.
- Distribuitor
- Coil
- Sparks wires
- Exterior Fuel Pump
What's happening?
Thank you!
