I'm repairing Toyota Harrier ACU# (Automatic transmission) with no reversing problem. When gear is shifted to R she throws codes P0717 (input speed sensor A no signal) and P0793 (Intermediate shaft speed sensor no signal) and she does not enter in reverse gear. Oddly enough when reading live data (used both Toyota techstream software and Autoboss V-30) I see vehicle speed is 255 km/h but the vehicle is stationary
WHAT I HAVE TRIED SO FAR
1)I changed the Complete Automatic transmission and made sure AT fluid is on required level but no luck
2)I checked input shaft speed sensor and intermediate speed sensor but they are all okay, even tried to replace them but problem persists
3)Then I thought maybe ECU is faulty coz of the odd vehicle speed value I was getting and decided to replace the ECU but no luck
4)Inspected solenoids but they are all okay.
Currently I'm thinking may be due to ECU recognizing vehicle speed of 255 km/h(though vehicle is actually stationary) it forbids AT to shift Gears(shifting gears at that speed is dangerous and may kill the AT). But my assumption leaves me with un-answered qns like WHERE DOES THAT VEHICLE SPEED OF 255 KM/H COME FROM WHILE VEHICLE IS STATIONARY?
I tried disconnecting ABS ECU and the Wheel speed sensors But the vehicle speed still reads 255km/h on DATALIST
If ECU was faulty then why even after replacing the ECU I still got Vehicle speed of 255km/h
Those are just my ideas, can you guys help me how to fix this issue please
255
is suspiciously the maximum value that a computer byte can hold. Too many pulses coming through? – Weather Vane Nov 13 '20 at 11:22
