So i was driving yesterday n the car shut off. I lost acceleration first then the car shut off leaving all my lights on. I pulled over turned it off then tried to turn it back on n i got nothing. No clicks no turn over no nothing. Had it jumped but only lasted a few minutes n the same thing happened. Had the same thing happen my in 03 maxima, after replacing alternator and battery multiple times it didnt help the car. So i know its not the same in this car. I have three codes that show up .. vehicle speed sensor n an o2 sensor. I was told its the speed sensor.. My question is... where is my speed sensor located.
    What were the codes? Do you mean the vehicle speed sensor or the crankshaft position sensor? A VSS won’t cause a car to no start.
    – Ben
    Aug 8, 2018 at 16:44
Its located on top of the transmission, you may have to remove some parts to get at it
