I just bought a Tesla Model 3, and it's full of artificial leather (seats, dash, doors, center console...)
When browsing car detailing/maintenance stores, I find 2 separate "classes" of cleaners and shampoos:
  • Plastic, rubber, vinyl
  • Leather
Should I be using products intended for leather, or products intended for plastic/rubber/vinyl?
There are no products I can find that mentions artificial leather.
The manual doesn't help much, except I now know the artificial leather on the seats is called "Polyurethane":
Dashboard and Plastic Surfaces
Do not polish the upper surfaces of the dashboard. Polished surfaces are reflective and could interfere with your driving view.
Polyurethane Seats
Wipe spills as soon as possible using a soft cloth moistened with warm water and nondetergent soap. Wipe gently in a circular motion. After cleaning, allow the seats to air dry.
Tesla Model 3 Owner's Manual, page 163
  • What does your manual say?
    Jan 1, 2020 at 18:49
  • @SolarMike That didn't occur to me to check. I added an excerpt to the question. It doesn't help much.
    – Hubro
    Jan 1, 2020 at 22:11
  • That actually seems very clear. Good safety tip with don't make the dash shiny, and clear instructions of how to clean the seats - what more could you want - except for someone else to do it for you...
    Jan 1, 2020 at 22:43
  • @SolarMike I didn't say it wasn't clear, but it doesn't help much in answering the question I asked.
    – Hubro
    Jan 1, 2020 at 22:46
    Warm water and nondetergent soap. Unless you have some nondetergent soap then you need to go shopping.
    Jan 1, 2020 at 22:48
Artificial "leather" is a plastic-like material.
I'd use a cleaner for plastic/rubber/vinyl and not an actual leather product.
You might check the Owner's Manual and see if they recommend a specific type of product or an actual product recommendation.
  • I added an excerpt to the question from the "Cleaning" section of the manual that mentions the dashboard and seats. The seat material is polyurethane, if that helps. They don't recommend any specific type of cleaning product, just that it should be "nondetergent".
    – Hubro
    Jan 1, 2020 at 22:12
