2001 Toyota Tacoma 2WD 2.4L 4cyl
92k Miles
I have a chirp/squeak coming from the area near my power steering belt.
When I spray it with water the noise goes away, but quickly comes back.
Here's a video of the noise and water test
Happens consistently - both from a cold start and when warmed up.
All 3 accessory belts (power steering, AC, alternator) are less than a year old; replaced about 1k miles ago. Continental belts.
It's just recently started (i.e. it didn't start after putting on the new belts)
Don't have a calibrator for the tension, but it doesn't feel loose.
[Here's a video of the noise and water test...]( https://youtu.be/ckFZrEBgRyA)
My next test will be to remove the belt and try spinning the power steering pulley manually, checking for play/noises, but was curious to hear what others think/where they would start.
  • What quality of belt did you buy when you replaced them? Its definitely belt noise, worn out pulley belt grooves can cause this also.
    – Moab
    Sep 26, 2019 at 16:00
The tensioner for the power steering was loose and wobbly. Tightened it up and the noise went away.
