Is the distributor in a 1993 Camry considered (electronic) ignition system? I've noticed that it has points & a condenser that can be replaced inside of it
2Welcome to Motor Vehicle Maintenance & Repair! Looking at the one, it looks electronic to me. Has all the guts of an electronic one... there's a Hall effect sensor right underneath the rotor ... I'm not seeing a condenser or points in it, so don't really know what you're suggesting. – Pᴀᴜʟsᴛᴇʀ2♦ Aug 23 '19 at 2:18
Add a comment
It is definitely Electronic, here is the diagram for the 4 cylinder, v6 is similar.
Points started phasing out in the mid 1970's.
