I have a CRAFTSMAN 3 Ton Floor Jack that I'm refurbishing. I've removed the rivets from the rear wheel assemblies to make it easier to paint. What should I use to replace the rivets?
Part
Axle width
Wheel width
Wheel hub inner diameter
Frame axle hole diameter
Frame thickness
Original rivet (axle) diameter
Measurement
1.8365" (46.6471 mm)
1.3440" (34.1376 mm)
0.4335" (11.0109 mm)
0.4180" (10.6172 mm)
0.1845" ( 4.6863 mm)
0.3830" ( 9.7282 mm)
I've gotten a recommendation to use this 10 mm x 1.5 mm x 60 mm class 10.9 flange bolt but it has a body length around 34 mm. Part of the wheel and frame will be supported by the threaded portion. Is this okay or is there a better alternative?
