So I have a 3-ton floor jack that can lift up to 18.5 inches high. I tried lifting a small SUV and discovered that the floor jack point is so high that the total hight I lifted the car was only around 5 inches. This was just barely high enough to get jack stands at minimum (nothing dialed in) height under the jack mounting points.
Any inexpensive alternative way(s) to lift the SUV higher in a home garage?
I am aware of a build your own ramps answer
