My tires look new but I just bought the car and I don't know for sure. They all look good except one rear tire which has cracking between the treads but nowhere else. Is this an accident waiting to happen?
  • Welcome to Motor Vehicle Maintenance & Repair! Commented Mar 8, 2019 at 16:09
Cracking is... not good. Usually it's a sign of a tire that's either been stored incorrectly or more likely pure age.
Get it changed - tires aren't something to take chances on.
It's probably worth checking the age of the other tires while you are at it. You can work out the age of a tire by looking at the DOT code - this should be a 10-12 digit code (usually prefaced with "DOT") stamped on the sidewall of each tire. If the tire was made after 2000 then the last four digits of this will tell you the year and week the tire was made. e.g. 1603 would be the 16th week of 2003.
Really if your tires are more than 10 years old they should be replaced, regardless of whether they are showing any visible signs of wear or cracking.
    Thank you for the response...i replaced them this afternoon they were all dated 2014 but 2 of them had started cracking and 1 had cupping..i bought 4 new ones and saved the best of the old for my spare-plenty of tread and no cracking on that one.
    – Lexus2001
    Commented Mar 9, 2019 at 21:59
-2
Not with modern tires, at speeds under 90mph.
You are safe even if nylon or steel is showing, but use your head, and be more careful if you have older tires
    Not just wrong..but dangerously wrong. Commented Mar 26, 2019 at 10:50
