My'92 Toyota P'up runs great, has had thorough annual maintenance since purchased new, & odometer is now at 166,500 miles. My last smog check indicated that the M1: 15 MPH "HC" (PPM) MEAS was 95, which is the MAX limit, per the inspection report. (All other test result variables were well within normal, passing ranges.) The smog tech. told me that, due to the subject "HC" level, it would not pass my next smog test, and offered no corrective suggestions.
So, I have been advised (variously) to install an new Catalytic Convertor, add Seafoam Motor Treatment to the gas tank, get a tune-up a week before test, etc. I would appreciate any & all educated opinions in my effort to get the "HC" MEAS. down to passing levels, if that's at all possible. Thanks!!
