My ford figo diesel not starting . Fuel pump overhauled , it is showing pressure when tested in machine . After fitting it is not starting . If starts rev going up and down 1000 to 1500 rpm and after few mints engine stops . Injectors checked . Engine checked in lathe for compression leakage pistons with rings are new . Fuel pump relay in fuse box located behind globe box checked , also been exchanged with same one . Ignition switch when put in 2nd position 8 beeps heard . Checked with digonasis tool everything showing ok only abs sign is not going off .Still engine is not starting . Please suggest me where I have to look through to solve the problem thank u
Did this problem only start after the fuel pump overhaul? – sam Jun 27 '18 at 14:44
No , I had changed piston and rings with bearings after fitting the engine it started and was running 3 hrs .during servicing of clutch suddenly it stopped and was not starting . Diagnosed by ford digonasis machine said no fuel. Pressure so the pump was overhauled after fitting the problem still remains . So replaced the pump with a pump from running engine still the same problem remains – Ani Jun 27 '18 at 17:47
I know back in the day ford had a reset button in the trunk. After you check that,replace your fuel filter. Very inexpensive.
