I have purchased an Exide Power MF Battery 120 A/H for my home inverter. I need to use that inverter only when there is no electricity. That can happen once a month or like that. So my question is, If I don't use the above semi-sealed battery every day, will it have any adverse effect? I mean, will it do damage to the battery? In other words, do I need to use it every day with an A/C current charger?
Here are the 2 options which I have with my inverter and battery.
Option 1: Charge battery using an A/C current charger and use it every day. I don't like this option due to it making a loud noise. I mean the noise emitted due to the charger and inverter.
Option 2: Use my inverter and battery only when there is a power failure. I would like this option, but due to not using the battery regularly, will it damage the battery?
