I've got a 1999 F250-SD XLT 4×4 that the coil just popped out of the head what would cause that? I've not done anything to it yet
  • Does this engine have one coil-per-cylinder? If so, pull it all the way out and look for spark plug damage. If the plug is shattered, you want to know as soon as you can.
    – JPhi1618
    Commented May 24, 2016 at 20:48
  • Last time I saw that happen, the spark plug had blown out of the head. (the spark plug hole was stripped). If the sparkplug is fine and attached and there is no gasoline in the hole (down to where the coil/plug goes), then I'm not sure what would cause it. Commented May 24, 2016 at 21:12
  • "@JPhi1618" yes it has one coil-per-cylinder when I looked at it the plug was gone "@user3188168" yeah your right it did blow out of the head I put another plug in it to see if it was stipped out but I don't know it grabbed but its got a miss in it so I don't know if it needs to be rethreaded or not?
    – Cameron
    Commented May 25, 2016 at 21:27
Your spark plug was loose
If the spark plug was loose and gone, based upon your comments, the coil did not pop out of your head, the sparkplug popped out of your head.
The last change of the sparkplugs may have been the cause where this particular plug was not properly torqued down in your head. If your threads are stripped in the head, which I doubt, then you have much bigger issues and will need to remove the head to repair the spark plug threads and then re-install.
Properly torque a new spark plug into the head and put the end of wire coil back on it, go for a test drive. I'm sure it will be fine.
Unfortunately I'll bet you've suffered what most every Ford Triton engine owner has. These engines blow plugs quite easily. There was even a class-action suit(s) at one point.
You won't be able to just "rethread". You have 3 options (but really only 1)
  1. buy as many different spark plug brands as you can, and carefully torque until you find one that grabs some. Don't overtighten. I've even had some luck in crushing the threads slightly oval in a vice. This is totally shadetree, and only for the folks that can't possibly afford the $400 fix before due at work in the morning. Probably won't last, but gives you some time until #3.
  2. Buy the taper thread repair kit and the special very long-nose plug that comes with it. This may or may not last, depending how much original thread is left, but all the ones I have repaired had already attempted this fix and maybe got 2 months to a year.
  3. Have it properly rethreaded, and "helicoiled" (thread insert) for the original style and size plug. This is an expensive kit, and not an average DIY job. Check ALL the plugs, and replace them once a year regardless of mileage.
If you want try try #2 or #3 on your own, here's a tip from an oldtimer:
Set the piston to BDC, and fill the cylinder with foamy shaving cream (not gel) until it squirts out the plug hole.
THEN do all your tapping, thread inserting seating, test fit plug, etc.
THEN remove the plug, put a shop vac over the open hole (might have to put a hose reduction on the nozzle, and suck out the shaving foam (and little bits of aluminum) while a helper SLOWLY hand cranks the cylinder back to TDC.
Clean off the plug, away you go. Good luck. Sorry that happened but you are certainly not alone.
