I recently got my 2004 VW Passat B5 a new MOT, but they said that an advisory item that would get worse over time were worn outer CV joints. The car creeks when turning on full left lock, though I haven't checked the full right lock recently. There is also grease coming from the nearside CV joint.
What is the exact roll of this particular part?
Is it a fairly straight forward procedure to fit a kit like this?
What tools might you need (a list of all required would be ideal as I have almost nothing)?
Anything I should watch out for that could be easily damaged in this process?
I have never done anything on my car more than replace a fuse or a door lock in the past so I'm trying to see if I'm way out of my depth here.
