After a severe pothole, I bent very slightly my front right rim right before a road trip. As the effect wasn't noticeable, I went on my road trip.
I noticed the clamp on my CV boot had gone loose on the side which points the wheels itself.
I am just wondering is it, in theory, possible that the bent rim is causing too much vibration and therefore loosening the clamp or was that just a result of a bad repair job (a couple of weeks ago I had the boot replaced after I ran over a shoe which tore it open)?
P.S. I'll fix the bent rim this week most likely.
  • The bent rim was not likely to be the cause of the cv clamp being loose. But you need to get this sorted properly.
    Commented Sep 30, 2018 at 19:28
    Thanks for the reply! The shop took responsibility and fixed it for me at no cost on the same day I reported it. They're my go-to guys and I accept a mistake sometimes happen and they dealt with it properly. It has been fixed for around a week with no issues but I had been second doubting the bent rim as a possible cause.
    – Tisho
    Commented Sep 30, 2018 at 19:33
  • Welcome to Motor Vehicle Maintenance & Repair! Commented Sep 30, 2018 at 20:18
A bent rim, even one severe enough to cause vibration, will not loosen a CV clamp that is already subject to constant vibration.
