Took a recently purchased used vehicle to a VW dealership for a checkup/ oil change
One of the things they found is a leaking outer C/V boot (driver side front tire)
They didn't seem to think repair was urgent, but due to an aftermarket axle, they said they need a new axle to address the leaking boot.
My question is can this problem cause other problems? I've never even heard of a C/V boot before yesterday. I want to know if this is a repair I should rush or something I can put off for a few weeks or months?
  • What is the year/model/engine/transmission of your VW? Dec 20, 2017 at 0:34
  • @Paulster2 it is a 2002 pasat wagen automatic transmission v6 engine
    – hellyale
    Dec 20, 2017 at 0:36
I've read that a CV joint can take a while to fail but when it does you can lose control or the axle can spin about and break some nearby parts that get caught in the chaos. A leaking CV joint basically succumbs to corrosion as water infiltrates into places it shouldn't be. Outer CV joints will eventually begin to give a terrible click/click/click sound as you make sharp turns.
Here's a straightforward symptoms link https://www.raxles.com/axleparts.aspx
This is a good discussion in this area too Can My Wheel Fall Off From a Bad CV Joint?
And then here's a Volkswagon specific video where this fella comments on a situation where the need for an OEM genuine part Volkswagon axle was called for to avoid driveline vibrations that you can get with aftermarket parts 2003 Jetta Vibration Diagnosis- Is it Driveline, Clutch, or other?
If the boot is leaking, then it is the grease coming out and a lack of lubrication will cause the cv joint to fail.
Depending on the design then it may be possible to fit a new outer cv joint or it may be a complete shaft.
As for how long, that is the length of a piece of string type question...
  • 5
    Not sure how bad the boot is, but a torn boot will also allow dirt and road grit to get into the bearing, making it fail even quicker.
    – JPhi1618
    Dec 19, 2017 at 21:07
