So I have a 1999 Ford F250SD XLT 4×4 that won't go into 4-wheel drive low. It's a manual shift 4×4.
What can cause this?
When I put it in 4-wheel drive high, the 4×4 dash light comes on but it doesn't seem to be working.
  • You should probably check the vacuum lines to the hubs there will be a solenoid somewhere in the engine bay that get's vacuum from a reservoir and then passes to the hubs.
    – Ben
    Commented Feb 25, 2016 at 21:50
  • I've had the same issue in s 4x4s. Vacuum lime all three times. Commented Feb 26, 2016 at 5:28
  • It could be a problem with your transfer case. I just rebuilt one I'm my Jeep that was having similar issues. The shift forks were worn out. There was no grinding noise either like you'd expect.
    – JaredW82
    Commented Feb 27, 2016 at 7:50
  • Have you ever serviced your transfer case? Have you checked the fluids in it? Is there a lot of metal in the fluid?
    – JaredW82
    Commented Feb 27, 2016 at 7:54
