Ok I don't know Jack about diesel, but i am learning as I go! It has been running out of fuel when the DTE is at 65-58 miles and its keeps climbing. When i first got the truck a year ago it ran out at 38 miles.... Now with that being said that is NOT my issue or even my concern. But what is the other day i ran out of fuel, put $30 worth of fuel in it, turns over but won't start. Just in the past 7 month i have replaced: (routine maintenance: oil filter, glow plugs, fuel filters) (non routine:) starter, throttle pedal, IPR, MAP sensor, ICR sensor, and exhaust pressure sensor. Its acting like it's not getting fuel but it is getting fuel. I'm lost as to where to go from here?? My only other thought is to really give it some fuel and some EXTRA heat to go with it!
  • Hi Amy. It's possible that this previous question has answers that apply to your specific situation: mechanics.stackexchange.com/q/12052/57. Note @Paulster2's answer: it's possible that one or more components in the fuel supply chain have been damaged. – Bob Cross May 27 '19 at 17:46
  • @Bob Cross- thank you! Its a start, I'm gonna go check a couple more things with the fuel system, let you know how it turns out! – Amy Renee May 28 '19 at 12:51
  • good luck! If you figure it out, please come back and answer your question here. It will be a trail of breadcrumbs for the next person with a similar problem! (Plus I’ll vote up your answer ;-) – Bob Cross May 28 '19 at 15:20
