I have an '04 Echo that had the sway bar link replaced. However, a new annoying sound has developed. It usually happens when I'm starting from a dead stop, or going over bumps at low speeds. The sound is quite similar to when the links were completely disintegrated, but not nearly as frequent and without the swaying on the highways...
When I swapped out the snow tires, I tried to jiggle the tire, tie rod ends, the sway bar link, but didn't notice anything. I figure it could be that the links needs to be retightened, and the passenger side is a bit looser than spec, but that didn't cure it.
What else could be wrong? When I took a look at the manual, sway bar bushings looks like a very difficult job...
