video where i check all my fuses: https://www.youtube.com/watch?v=74YimFvXEsQ
fuses that lighted up without key:
11 Moonroof (20a)
12 accessory power socket (with idk why it did since it doesnt give power to my 2 usb charger port i have.) (20a)
27 accessory power socket (same above except i have radar dectector in there) (20a)
38 left headlight high beam (10a)
39 right headlight high beam (10a)
40 TPMS (7.5a)
41 door lock (20a)
42 Driver power window. (20a)
fuses that did lightup with key.
19 to 22 confirm
19 acc (7.5a)
20 acc key lock (7.5a)
21 daytime running lights (7.5a)
22 hac (7.5a)
now which fuse should i use for yellow wire? (need power without key) , im going to use fuse#19 for red wire. Finally on grounding my bolts are way too tight and hard to reach. except maybe the one thats right next to my fuse box. can i use that as grounding point?
