So I was upgrading my HID lights to LED, but I had to change one of the socket wiring harnesses. I asked for my friends help with rewiring, because i wasnt sure which wires went where...so he looked some stuff up and helped me replace the socket. At first, it worked, but when using the high beam, it turned the lights off completely. I was convinced that it was a wiring issue so I did what I should have done at first and took the old socket apart to see which wires go where, and found out it wasn't connected right.
I then rewired it again, to mimic the old socket, and when I fired it up this time, no lights work at all. I am positive it's wired correctly, and I also checked the under-hood fuse box and the fuses looked fine for both the left and right headlight.
Then I noticed, one of the headlight fuses seemed to control both headlights, and the other one didn't seem to control anything. the odd thing is that if I plug my good HID bulb in, it works, high and low beam, but it also has it's own custom wiring and does not use the OEM socket. I just want my OEM sockets working again so I can use these LEDs, but it seems like I may have a wiring issue.
I have uploaded some images to imgur since they are apparently too large to upload here. If any other information or pictures are needed please let me know. Thanks!
