I wanted to know if I could replace a 1.6 8v block with a 1.8 8v block, and if it would be a straight swap, or if any modification would be required.
My current block has a hole in it, so needs replacing but I am not currently in a position to do a complete engine swap.
  • Welcome to Motor Vehicle Maintenance & Repair! What years are both of the engines? Commented Oct 19 at 13:51
  • The one currently fitted is 1991, and the replacement block would be from the same model vehicle i.e. a Mk2 golf also. Commented Oct 20 at 15:15
