21
I would like to know the proper oil to use in a Ford GAA engine from around 1945. Could be as late as 1958.
Ford GAA with valve covers removed
From a series of photos of a GAA being restored on Flickr.
Currently this engine has all the original seals and gaskets and showed no signs of leaking when I got it.
I do know the bearings are silver babbitted and the block, heads, and covers are aluminum. It has brass cam gears and a gearbox upfront to run the magnetos water pump PTO shafts and cam drive shafts.
I am thinking this is going to be a pretty heavy oil maybe a straight 50 weight or something but not sure. I have not found any parts list that has a part number specifically for this engines oil. I do have a copy of the GAA / GAF / GAN service manual but any other documentation would be great.
4 Answers 4
28
Per @Eric Urban's suggestion,
I found the Technical Manual for the M4A3 tank published in 1942. That tank did use the aluminum Ford GAA 18L V8 engine which produces 500 hp at 2600 RPM!
It says:
Capacity: 32 Quarts
Above 32°: SAE 30
32° to 10°: SAE 30 or 10
10° to -10°: SAE 10
Below -10° : Not Listed
Replace the oil every 50 hours or 500 miles on dirt roads or 1000 miles on paved roads. (These are miles in a tank.)
Clean the oil filter every 1000 miles.
I believe @user23543 has a point that oil formulations have changed over the years.
In 1942, the SAE J300 standard was much different. It was only concerned with one viscosity and tested that in a much different way than today. They used a different test apparatus and different temperatures.
Some say, "the minimum standards for each grade have only become more demanding [over the years]". That's a good general rule, but it's not that simple.
SAE J300 started out measuring just one viscosity of the oil with a "crude" apparatus. Nowadays, SAE J300 prescribes the grades by listing the viscosity under several different conditions.
Today's oils are probably overall better than back then, but since we do not know the other viscosity numbers from back then, we cannot make a full comparison.
I have been unable to find the revision year of SAE J300 that was applicable in 1942. I have also been unable to obtain a copy of the original SAE J300 standard published in 1911.
The original SAE J300 compared all oils the same; it did not break "oils" up into the various categories we have today.
Illustrative points:
  • Prior to 1947, oil was not divided into Regular Type (mineral oil), Premium Type, and Heavy-Duty Type (contains detergents). (source)
  • Prior to 1952, oil was not divided into gasoline and diesel engine categories. Even then, that was part of the API standard, not SAE J300. (source)
  • In 1952, SAE added the winter ("W") grade. (source)
The viscosity of SAE 30 back then and the viscosity of SAE 30 now are similar, but not identical.
I have no information on any of the other properties that we take note of today from the oil back then.
SAE 30 is a good starting point though.
10
  • You're awesome!
    – Cc Dd
    Nov 2, 2016 at 4:20
  • @CcDd Gave you 5!
    – 0xc0de
    Nov 2, 2016 at 5:28
  • Sweet! Just need 2 more :)
    – Cc Dd
    Nov 2, 2016 at 6:33
  • I did not think it would take basically a regular 10w30 oil. Especially with the gear train up front.
    – Cc Dd
    Nov 2, 2016 at 7:41
  • @CcDd I'm not sure what you mean. If you check out that manual, it has several pages on the different parts that need lubricated. The manual was published in 1942 and you say the engine could be as late as a 1958. Best practices may have changed in those 16 years. Nov 2, 2016 at 11:49
8
Given the changes in oil formulations since the time this beast was built and now, I'd consider a change in the oil. Straight-weight oils as formulated then and now are considerably different.
Were it me running such an engine (and I work with antique engines on a regular basis) I'd be using a 15W40 Diesel oil in it.
Modern oils over the past few years have had the levels of ZDDP (anti-galling agent) reduced in them dramatically - and with a whitemetal bearing engine (not sure of the tappet type - if it's flat-tappet more so) you want the extra lubricity.
In my home shop I stock 15W40 Diesel oil in bulk and all of the engines suited to it get that. The modern hardware my wife drives get the recommended oils, but all of the antiques and my daily driver Diesel get the 15W40.
  • I was also leaning to higher up I was eyeing a 15w50 or even a 20w50 with a zinc additive. I am more worried about current detergent packages in oils and if they might eat through the original gaskets. Might use valvolines vr1 20w50 which should have less detergents and much more zinc.
    – Cc Dd
    Nov 3, 2016 at 3:05
The Ford GAA was originally manufactured for the M4 tank and other armored vehicles. I recommend finding the maintenance manual from the US Army for one of those vehicles, then working your way forward. You are very unlikely to find the exact oil they specify, but should be able to locate a substitute. Contacting a museum with a running M4 that uses the GAA engine would be a good place to start.
  • correct sort of. The history behind it is rather fascinating and I am trying to piece that together as well. Started as an aero engine which was conceived because of Henry Fords ego. He got lucky when the army came back and asked for a tank engine. I have been looking for a M4A3 service manual but can't find any. Yeah need to call around.
    – Cc Dd
    Nov 2, 2016 at 0:44
I have a 1929 Vauxhall Cadet, I always use 20W50 in its 6cyl 2.2L engine. It has always run perfectly. Chances are the original oil is not available anymore, or other oils from these days are way better anyway.
That engine looks totally awesome by the way!
  • Thanks! I am hoping to install one of the 3 that I have into a 74 ford econoline 200. This will be a test project. I will find a way to rebuild worn out engines that do not have a 2nd set of oversized parts. Possibly using diesel pistons rings and con rods. Then I can give new life to older used engines in museums and tank collections. The other 2 I am not sure but I do want to modernize one. I can say I cannot look at a big block anymore without realizing how small it is.
    – Cc Dd
    Nov 4, 2016 at 5:35
  • @CcDd Totally awesome to build such a tank engine in a car. If it sounds as good as it looks, it'll be the most badass van ever. But dude, i hope you understand that you must get a heavily(like, reaally heavily) uprated driveline along with it, otherwise you'll completely warp your driveline, or even the entire car. It must be huge to cope with the torque that that engine delivers.
    – Bart
    Nov 4, 2016 at 7:13
  • it creates 550BHP and 1060ftlbs of torque stock. probably going to use an e450 frame and rear axle for it. To keep it all ford going to try and build or get a c6 that won't explode too quickly. The first one will be pretty much stock but I do plan on boosting one in some other project.
    – Cc Dd
    Nov 4, 2016 at 20:02
  • @CcDd So you've thought about that, good. You wouldn't be the first to heavily underestimate the forces(1400nm holy shit) that come into play when introducing such an engine to a standard van. If the frame and the tranny are designed to cope with such power, you're good to go i suppose. In that case i guess you have also taken suspension, centre of mass, and driveability into mind. Would be nice to have a hall of fame here where you can show these kind of projects.
    – Bart
    Nov 6, 2016 at 12:17
