K7M engine (Renault Sandero)
During a timing-belt and tensioner change, I used a locking-pin(an 8mm bolt) to hold the engine while breaking loose the crank-pulley bolt.
Not being an experienced mech', I'm concerned I may have inserted the locking pin at the wrong phase in the 4-stroke cycle(*), and was wondering whether that might have damaged any of the internal moving engine parts e.g. piston, valve, cylinder.
I had to apply quite a bit of force to get it loose and at some point I noticed the bolt I used as a locking pin was slightly bent.
- I noticed the pin would go in to varying degrees/at varying lengths depending on the current phase. I since found what I think is the best position in the cycle to insert the locking-pin i.e. just before TDC on cam-gear.
