I need to bond (or RE-bond) a piece of what appears to be a hard plastic lining onto a cam chain guide used in a Kawasaki KZ400H. It appears the OEM plastic piece was originally glued to the cam chain guide with some sort of adhesive, because it just came off when I tore down the engine. I need an adhesive that will bond permanently to aluminum and stand up to high temperature in an oil environment. I'm thinking about Pliobond 25, or something that I could heat the part with (if I have to) that would produce a very permanent bond, very important for a part that – if it came off and meshed with the engine's gears – could result in a very bad crash if it happened at speed. Any ideas?
    Replacement of the part (with part glued to it) is probably wiser. This is my go to for gluing metal to phenolics, (you can speed the cure a lot with heat, or you can wait) not sure about the oil-bath aspect. ellsworth.com/products/adhesives/epoxy/… Just a happy customer. I like that it can be made stiffer or more flexible by altering the mix ratio, and I've used it on a serious structural project that had to be electrically insulated...
    – Ecnerwal
    Commented Sep 12, 2022 at 22:02
  • I threw a rod through the side of my lawn tractor engine block. I used JB Weld to glue the 2" piece back onto the block and it held for years despite the heat. Normal epoxy softens with heat.
    – RetiredATC
    Commented Sep 13, 2022 at 4:38
    I'd be very reluctant to use any sort of adhesive in this application. Your best bet is to find a suitable replacement part.
    – jwh20
    Commented Sep 13, 2022 at 13:14
  • That's not going to happen. Smooth aluminum or plastic are not bondable because they don't have any "jaggies" for the glue to bond to. Commented Sep 14, 2022 at 1:36
