What's a safe way to remove wax from a plastic motorcycle fairing? I may have used an inappropriate cleaning product in the past, and UV may have made it worse.
side fairingsfront
I can remove some of it with friction (photos show traces left by fingernails), but I'm just tossing it around for the most part. Dishsoap doesn't do anything. I'm thinking maybe a kitchen vinyl de-waxing cleaner might work.
Once clean, I might try some of the rejuvenation solutions mentioned below. They're not quite what I'm looking for however.
the product
Here's the last cleaning product I've used (last year, before storage). There's no clear indication from the label that would discourage use on plastics. The wax is carnauba, a hard wax which comes from trees.
simoniz frontsimoniz back
Simoniz high-foaming wash and wax, fortified with carnauba wax, pH balanced. Rinse vehicle to remove dirt. For best results wash vehicle in the shade. 60mL per 4L of water. Apply with Sponge. Rinse with water. Dry with cloth or chamois. No surface compatibility warnings. No phosphate.
Update:
I've tried a scotch brite, "VIM Linoleum and Vinyl kitchen floor cleaner" in hot water, and elbow grease, and I've managed to make some of it go, but It's a marginal improvement -- it looks slightly better, but that's because it's a sunny day and the photo is washed out a bit.
slightly better
After vinyl kitchen floor cleaner. a tad better
Hard to say for certain what will work without knowing what the substance actually is - washing up liquid is normally pretty good for stripping off most waxes, but as you say it's not done the trick here. You could stay on the same tack but up the firepower a bit by going with something like Meguiars Super Degreaser - I've used this to clean polishing pads before so it definitely can shift polishes and waxes.
You can try it at 10:1 dilution initially and if that doesn't do the trick you can take it up to 4:1.
If you do go down this route then you'll want to make sure you rinse the paint work off thoroughly afterwards and ideally apply an appropriate protective layer of a suitable sealant afterwards.
It's a bit annoying to purchase a gallon of stuff to just clean one fairing though (especially given it's not exactly cheap!). Although you can of course use it for when you want to clean engine parts etc in the future.
Alternatively a good tar remover is worth a try AutoGlym Intensive Tar Remover is very effective for taking tar (duh!), tree sap and glue residues off paintwork without damaging them - so it might work on whatever is on there. It's just hard to say without knowing exactly what it is!
If that doesn't shift it you could try using a claybar - you'll want to make sure the paintwork is free of any loose dirt before hand (a regular wash with any car shampoo that doesn't contain wax or even washing up liquid is fine) and then rub the panel with the claybar (taking care to keep it lubricated with quick detailer). I've never tried a claybar for this sort of job but can see how it might work.
Update to correspond with that in the OP
"Wash and Wax" is extremely unlikely to be the culprit here - unless there was something drastically wrong with either the fairing itself or the particular bottle of Wash and Wax. The Simoniz stuff isn't particularly great IMO, but it's not "mess up your paintwork" bad either. Just straight up middle of the road.
You might see a similar effect if you washed it with a fairly high concentration of wash and wax on a really hot sunny day when the panel was already hot - but I'd be surprised if the residue was as persistent as you describe from those factors alone.
I don't know enough about the VIM Linoleum and Vinyl kitchen floor cleaner to know what that will have done but the scotchbrite was ill advised to say the least. That's way, way, way too harsh to use on automotive paint. Sorry to say it but the chances are you've done more harm than good with that.
I appreciate that this may be a little too late in your case but for the sake of future readers:
NEVER USE A "SCOTCHBRITE" OR SIMILAR ON AUTOMOTIVE PAINTWORK
The course nature of these causes lots of fine scratches in the clear coat. Here's what one of my cars looked like after a previous owner had done just that:
Poor Subaru
You see the little circular scratch marks? Yep, done with a scotchbrite-esque scouring pad. And that picture was taken after the car was cleaned, it had been throughly washed and clayed at point - that's the bare clearcoat you're seeing.
All the fine scratches the scourer makes light hitting the clear coat refract at lots of different angles giving a unpleasant cloudy effect to the affected section of paint.
That little disaster took ~2.5hours of grafting with a machine polisher to rescue.
I don't know whether it's going to be that bad in your case - I'd need to see some decent close-ups to know how bad it is. The layer of whatever-it-was may have helped protect the paint, or perhaps the lino cleaner offered some lubrication protection of it's own. Or perhaps it's f##ked.
If you've got a decent bright LED or fluorescent work light wait for it to get dark and hold the light above the panel and take a close up photo at an angle to the surface of the fairing - that should give an idea of what state the panel is in.
  • I've previously had excellent success using T-Cut. Commented Jun 25, 2019 at 13:10
  • @SteveMatthews T-Cut would probably work as well - it's a little on the harsh side though so I'd be a little concerned about potential affects on the paintwork. The paint/lacquer on a thin plastic fairing like that could be on the thin side. It's possible it might even be single-stage paintwork. Definitely worth considering though! Commented Jun 25, 2019 at 13:16
  • added photo of the actual cleaning product. fairly certain it's carnauba wax. Commented Jun 25, 2019 at 22:38
  • yikes. i don’t think i damaged it, wasn’t a green scotchbrite on this occasion, just the blue sponge version with the non-abrasive beads. but really good to know! Commented Jun 28, 2019 at 19:15
At the risk of sounding like a prank, I'm going to suggest something I've used many times to remove wax that was unintentionally applied to cast plastic parts on cars, which can suffer from similar staining from typical car wax (i.e. bumpers, door molding, plastic mirror trim, etc). I learned this from a pro detailer many years ago.
Try a dab of peanut butter on a clean cloth. Rub gently into the plastic then wash and rinse with a typical car wash soap to remove the peanut butter residue.
The oils in the peanut butter will dissolve the wax contamination and lift it out of the plastic, and the peanut butter is "soft" enough to not scratch or mar the plastic.
    This actually works! It can be very effective on unsealed/unpainted plastics in particular Commented Jun 27, 2019 at 8:45
  • I've been doing it for 20+ years. In fact, I was doing this on my own bike last weekend. It's more effective than any cleaning product I've tried, to get unwanted wax stains off plastic. I'm known to be a bit of a joker in real life, so it's sometimes hard to convince people that I'm being serious when I tell them to rub peanut butter on their car...
    – dwizum
    Commented Jun 27, 2019 at 12:40
  • nuts! I've heard of a similar restoration procedure, with wd-40 wrapped in cling wrap around the fairing. Anything special about peanut oil in particular? I'm reminded of the team responsible of painting railings of the sydney opera house with olive oil (link) Commented Jun 27, 2019 at 18:47
  • @mvm_init_js The Sydney Opera House article is no longer working at that URL, but interested readers can view it on the Wayback Machine at web.archive.org/web/20201025015140/https://aooa.com.au/news/olive-oil-protects-the-sydney-opera-house/. Commented Apr 27, 2021 at 16:46
