I have a crank - no start issue on a Nissan micra from 1999. It is a 1.3 gasoline engine. Up to this point I found out there seems to be no spark.
- Put a new spark in a wire and placed it on the engine block. No sparks appear when cranking
- I opened the distributor and approached one spark wire to the ignition coil. No spark appears when cranking.
I guess I can safely say the ignition coil sends no sparks. On the other hand, I put a multimeter on the positive and negative leads of the coil when puting the contact on and there is power coming: 12V.
How can I test if the ignition coil is bad, or something else? On the old ignition coil, the resistance from the leads to the top seems to be 11.9-12kOhms. I also have a new one and when I test it, the reading goes up, then stabilizes to about 12.4 kOhms. Does that indicate the ignition coil is bad?
I plan on replacing the coil to see if that changes things. However, since it's a quite complicated procedure (for me...) I was thinking if there is a way of finding out if everything else (beyond the coil) is in order.
Thank you in advance for your advice.
