95 Acura integer makes a plastic buzzing sound for 15-60 seconds after startup. Sound eventually stops. Sound is originating from white box:
The goal is to understand the cause of the sound and corrective action. What are the steps to diagnose root cause of the sound? Any lessons-learned or relevant experience is always appreciated.
  • The white box you're looking at is the ABS module. The noise will probably be related to the ABS warning light you asked about in this question
    – user60481
    Oct 5 '20 at 13:58
This is the brake fluid tank. Underneath it likely has the ABS actuators, which likely make the sound you are hearing. I'd start by diagnosing ABS (with a scanner). If you don't have the scanner that can diagnose ABS - pull the ABS fuse and start the car to see if the sound is still there.
  • Thank you for responding. Are you able to provide a link to a ABS scanner? I ask because I am trying to understand if it is ODB tip scanner or a scanner specifically used only for ABS. Unfortunately the '95 misses the cut for the ODB2 compliance mandate
    – gatorback
    Oct 5 '20 at 23:50
  • @gatorback, yes, unfortunately '95 Integra does not appear to have OBDII. Here's a link to an forum post explaining how to pull codes on Acura without OBDII. team-integra.net/threads/abs-codes-94-97.173389
    – EᑎOT
    Oct 6 '20 at 15:09
