I am experiensing some black soot from the exhaust pipe of my forester sg5 turbo. This started after changing to a bigger turbo(td04hl). What could this mean and the advisable repair? Kindly
That you have not checked the relevant settings to match the different turbo. Why did you fit a larger, possibly incorrect, turbo?– Solar MikeApr 2, 2020 at 17:16
Welcome to Motor Vehicle Maintenance & Repair!– Pᴀᴜʟsᴛᴇʀ2 ♦Apr 2, 2020 at 17:18
1 Answer
There's three things I can think of:
- Bad tune
- A stuck injector, or
- You've got a leak in your charge pipe.
Soot indicates too much fuel (or conversely not enough air). If you don't find any leaks on the charge side, the mapping in your tune is dumping too much fuel, or you might have a stuck injector, also dumping too much fuel.
