Which tyre will be more abrased during right hand drift with Audi rear sport differential? My car is equipped with Torsen Quattro + rear electrohydraulic limited slip differential, it is an Audi S4 B8. I want to shave 0.5mm (1/32") of right rear tyre, which way I should drift? This is because I got damage to almost new tyres that have 7.5mm of tread while new have 8mm and they're expensive Pilot Super Sports.
  • On ice should be fine...
    Commented Mar 13, 2020 at 11:29
    Hi Yoda. Your question is a little hard to follow. Are you trying to decide if you can drift your car as a way to deliberately wear down a specific tire by a specific amount?
    – dwizum
    Commented Mar 13, 2020 at 15:56
  • If you are drifting your vehicle, tire damage is a given. Not sure what you are trying to accomplish. Shaving a tire takes tire off of your tires. My suggestion, either get scrub tires to put on while drifting, or ... don't drift. Commented Mar 13, 2020 at 17:17
    @Pᴀᴜʟsᴛᴇʀ2 He has an AWD car that has slightly uneven tires. I think it would be very difficult to precisely wear down the new tire to be even with the other ones. You will most likely wear down both rear tires somewhat before they even out. I think some people have mentioned tire scrubbing services that specifically deal with this problem. Commented Mar 13, 2020 at 17:30
  • Drifting your car you should not be, “Once you start down the dark path, forever will it dominate your destiny, consume you it will.”
    – Alaska Man
    Commented Mar 13, 2020 at 17:33
