I have seen videos on YouTube saying that flushing your engine or transmission oil can sometimes cause damage on old vehicles which didn't have regular oil changes done to them. Is there any truth behind this?
And what is the difference between flushing and draining? Does flushing require a special machine? Is it correct that when you drain you only remove half the oil?
  • please try to be a bit more spesific in your question,and limit the question to one car model or one type of transmission. Mar 5, 2020 at 15:49
In the most simple terms flushing means you are actively washing the old fluid out using some sort of other liquid (such as a detergent or solvent) rather than passively draining which is just allowing as much as you can to flow out of the system unaided.
In engine oil terms a flush is done by adding a special detergent to the existing oil and then idling the engine for ~10-15 mins and the engine effectively "pumps" the flush around the oil system cleaning as it goes. You then turn the engine off and drain it as normal.
Yes, unfortunately this a real phenomenon, sometimes the sludge/deposits that the flush clears away are actually masking a degraded seal. Meaning that while it's not done damage it's exposed existing damage and made it start causing leaks and similar problems.
The older and more poorly maintained the engine the more likely it is for this to be the case. If you suspect this is a possibility on an older car that you're just planning on using until it expires this means flushing is probably going to be a Bad Thing(TM) as tracking down and replacing the seals could start to get expensive. If it's an engine you are aiming to have last as long as possible and are putting the time, money and effort into bringing to peak condition then it can be good - you can address any issues the flush reveals and drive on safe in the knowledge that you are less likely to have a hidden issue waiting to bite.
Transmission fluid flushes are a bit more complicated - here a machine is often involved (which means finding a garage that has one) so it's going to end up costing you more. Here there are risks also - different to the engine but probably more likely. Depending on the transmission it's possible that a flush can push fluid into areas or in directions that the transmission wasn't designed for, and that can cause damage. Some manufacturers specifically warn against doing flushes for this reason.
The nature of the way a transmission functions also means there's a likelihood of small bits of debris floating around in the fluid from wear and tear - and a flush can push this debris in to places where it can do significant damage.
It varies - on most engines if a oil change is done properly you'll remove more than half, but it's unlikely to be all the oil, and if you do a couple of changes back-to-back (with about a 15 minute idle in between to circulate the oil) you'll get more or less all of it, but that's rarely necessary IMO unless you have particular reason to suspect the oil is compromised in someway.
For a transmission change this is more of a thing - many autoboxes will only drop around 30-33% of the fluid with a pan drop, which can be worked around with repeated fluid drains so that over time you effectively dilute the "old" fluid and replace it with new - doing a drain 2-3 times with some driving in between should pretty much do it.
  • So if I understood you correctly than flushing requires using some other liquid to remove the old oil while if you just add new oil with the car running then this is called draining. Is this correct? Mar 6, 2020 at 10:40
  • @Linux_user0987 broadly speaking yes - a flush involves using something as a flushing agent (typically a special detergent) but draining doesn't. You don't have the engine running when adding either flushing agent or new oil though. Any idling/running the engine is done in between add/drain cycles. Mar 6, 2020 at 12:55
  • So if I drain and add new oil till the old one is gone this is not a flush. But how can flushing be more beneficial (in some cases) if both ways the old oil is completely or almost completely removed? Mar 6, 2020 at 18:54
  • @ motosubatsu : Why didn't you reply? I asked if you drain and add new oil till the old one is completely removed then how can flushing be more beneficial if the difference is that you use some detergent while flushing? Both ways the oil is completely removed or almost completely. Mar 21, 2020 at 10:40
  • @linux_user0987 because the detergent used in a flush removes sludge/deposits that wouldn't be removed in a simple drain - they aren't are either a highly viscous fluid that won't drain or a solid which obviously won't drain. Removal of these may or may not be beneficial as the answer describes Mar 22, 2020 at 15:02
