I've got an OEM Suzuki ATV LT160 starter motor that's not functioning. I've seen replacement motors and rebuild kits.
When is it appropriate to try to rebuild a starter motor vs replacing it?
The choice of replacing or rebuilding parts is based on several factors:
Refurbishing a part saves you money at the cost of time, requires tools and skills, and may or may not be something you enjoy. Replacing a part saves you time at the cost of more money and you don't get the pleasure of fixing it yourself, presuming you do.
At $50 or so replacing the part isn't expensive, so if you just want it to work or don't have the tools then buy the replacement and put it in. You save yourself $30 using a refurb kit at the cost of an hour or two if you have the tools available.
