Not sure what might've happened, but I slept in my car for a little bit and mistakenly slept pressing down the brake pedal.
When I woke up, I tried to turn on the car and I wouldn't get any crank whatsoever and the ABS and Brake System lights would come on.
I tried manually pulling the break pedal up, but I didn't push it too much since I didn't want to damage some other mechanical system.
I then left the car, and locked my doors, to my surprise the car's horn didn't sound either, even though all the doors were closed properly (I double checked)
I have a Honda Accord Sport 2017 that I got brand new from the dealership, and this is the first mechanical issue I've had with it so far so I don't think it's a previous mechanical issue since I hadn't seen any lights before either.
Any ideas?
    Hi and Welcome. Sounds like you drained the battery (the brake lights were on the whole time). Charge the battery or jump start the car and go from there.
    – mike65535
    Oct 31, 2018 at 16:13
    @mike65535 - That sounds like an answer. Oct 31, 2018 at 22:55
  • BTW - Welcome to Motor Vehicle Maintenance & Repair! Oct 31, 2018 at 22:55
Sounds like you drained the battery (the brake lights were probably on the whole time you had your foot on the pedal).
