I have a 2007 Mazda 3. When I purchased it, it came with a soft brake pedal. I thought that the brakes needed bleeding, but after taking it in to get it bled, there was no difference and apparently it needed a new master cylinder. They was going to charge me quite a lot, so I went a head and bought one and installed it myself which didn't take very long.
I filled it with brake fluid, and kinda bench pressed the master cylinder when it was already installed (an error on my part).
I then tried to bleed the brakes with very little fluid coming out. I understand that it may have a lot of air in the system and it may take a while, but I've tried and tried but still not a lot of brake fluid.
I'm not sure what I could do next but I'm stumped. Any advice?
Thank you!
