I was driving my Honda prelude and all of a sudden it shut down and wouldn't start again. I pushed the vehicle to the side of the street and opened the hood. The radiator frame where the hose connected to was busted. No steam or overheating warnings came from the vehicle while driving. Is there more than just the radiator as it being the problem for reasons it won't start? Is the thermostat gone also and is that why there was no indication when driving that vehicle may have been overheating? It was very weird though that no smoke or steam was coming from the engine when it broke down. Could you offer some assistance.
Welcome to the site. First question is do you have any coolant in the system? Does the engine turn over when you try to start it? Do your other power systems (lights, fans, radio etc.) still work? There could be a number of reasons that the motor dies that don't involve the cooling system.– kyle_engineerCommented Sep 1, 2017 at 20:53
Does it sound like it has compression when cranking?– BenCommented Sep 1, 2017 at 22:32
Yes there was coolant in the system. Engine just died on the road. Won't turn over, radio, lights work.– user32032Commented Sep 2, 2017 at 7:09
You please share pictures of the internals– Lawyer AidroosCommented Aug 1, 2018 at 5:36
The coolant would of had to hit the engine for there to be steam, if the Crack was on the radiator and it poured directly on the ground that would explain no coolant - no steam– user38183Commented Nov 29, 2018 at 11:11
Show 1 more comment
1 Answer
What I got from the points you mentioned above is that there is something that hit the hose and maybe it also hit a wire (cam or crank shaft wire ?) which caused it to cut off the engine. If the car did not overheat, even when there is no coolant inside the radiator, the car should still start.
