I bought a BMW e39 with a bad transmission (ZF 5HP18). I bought another one in a junk yard and I plan to rebuild myself the one that came with the car and keep it as a spare. My question is: after I do the rebuild and put together the old transmission it will be dry without ATF how do I store it (for years)to avoid corrosion on the inside?
1 Answer
welcome on this site.
Good luck with rebuilding the transmission, this is one of the bigger challenges in car maintenance.
You need to store the transmission with ATF inside in a clean dark place with constant temperature. Do not overfill the transmission. Ideally the gearbox is wraped with oil soaked paper/rags
2While I agree with the premise here, there's one other thing I'd do. If you go to a regular transmission shop, they'll usually have plugs which can be used for the transmission. They'll either give them to you free or you can get them for a cheap price. Get one for the input and tail shafts. Then get smaller plugs for where the transmission cooler lines go into the transmission and a small one for the breather tube which is usually near the top of the transmission. If you can plug these up to prevent dust/air from going into the transmission, you should be able to maintain it indefinitely.– Pᴀᴜʟsᴛᴇʀ2 ♦Mar 18, 2017 at 21:06
