As a follow-up from how fast does the alternator charge the battery?, how powerful are alternators supposed to be at idle?
Specifically, if I have a lot of OEM accessories in my 2008 Jetta 2.5L SE, that are all turned on (e.g., heated seats, AC, defroster etc), or, if it's really hot and humid outside, and I have AC running at full speed, and the engine sensor is so hot that it turns on the engine cooling fans at full speed, too, and voltage immediately drops and stays below 13.2V (e.g., below 2.2V * 6), but is still above 12V, is there a problem with the alternator/voltage-regulator (mine's a combined part), or is that by design? (When the car is just turned on, or the power-hungry accessories are turned off and the engine cooling fans aren't running at full speed, then the voltage is between 14.4V and 13.5V, depending on how long the car has been running.)
