I just bought the car and in process of discussing the issue I have with the door keypad panel pulling away. The dealer promised to get a garage(close to my house) to fix it for me but I'd like to know how this can be also fixed. Just for my information so I don't get screwed over or something.
I found this forum where a person have similar issue and suggestion using glue/adhesives which sounds too easy or kind of unprofessional to me. But I'm not sure since this is a new car to me. Just using glue feels to me not enough but I have no experience with this brand.
How is this panel attached to the door?
Here are the pics of the problem: The driver's side keypad pulling away
it should be enter image description here
If adhesive was used by Ford in the first place, I would say that is fine. I'm not sure what is original, so this isn't a great answer, but it felt like more than a comment.
I had a trim piece repaired by a body shop and they used glue, but the OEM solution was plastic clips (that they had broken...). The glue failed after a year, and I had to go back and make them repair it properly with a new part. The glue might have worked in the short term, but there was a reason that VW (my car) didn't use glue and opted for clips instead. For that part, it wasn't going to last 10-15 years.
My point is, Ford has already researched and developed what should be the right way to do this, so make sure whatever shop does the work follows their recommendations.
  • well, I don't know if an adhesive was used in the first place. Thanks for your comment anyway.
    – Grasper
    Commented Feb 29, 2016 at 17:40
