2012 Volvo C30 T5 – While trying to diagnose an unrelated issue (“Engine System Service Required” message), I was trying to open the PCV diaphragm cover to check the state of the PCV diaphragm.
I pushed a little too hard with the screwdriver, and heard a “crack”. It seems that I cracked part of the plastic PCV housing, which now wiggles a little bit (it didn’t before).
I turned on the engine - no codes, it’s not pissing oil everywhere, and I don’t hear the telltale “squealing” PCV noise.
I did however notice that the idle sounded rough. Also, there was a smell of oil (I think).
How can I tell if I broke my PCV system? Is it safe to drive around until I properly diagnose it? Is there any risk driving with a damaged PCV system could lead to catastrophic engine failure?
Below is a photo of a replacement PCV. The plastic part circled in red is what I broke.
