So I opened my engine bay when the car was on and I heard this noise. I don’t know how to describe it, but it sounds kind of weird.
I do not know much about engines so I don’t know if this is normal or not.
I recorded a video, is there something wrong with my car? I am sorry if I come across as stupid.
here is the video
  • Have you checked your oil level? Are you using the right oil? I'm hearing a bit of valvetrain noise. What year is your G? How many miles on it? Regular maintenance? Commented Aug 2 at 23:38
It's difficult to diagnose a noise without hearing it, but I can offer some general advice. If the noise sounds unusual to you, it's always a good idea to get it checked out. Common noises could indicate issues like loose belts, problems with the exhaust, or even issues with the engine itself. If you're concerned, I would recommend taking your car to a mechanic who can listen to the noise in person and give you a more accurate diagnosis.If you can, try to describe the noise as much as possible (e.g., is it a squeal, rattle, or hum?), and include details about when it occurs (e.g., when the car is idling, accelerating, or braking). This information could help narrow down potential issues.
