I have a new 2.5 hp Mercury outboard motor on a used 12-foot aluminum boat. When I use the motor, it vibrates the boat and everything in it, which makes a lot of noise.
I'm doing what I can to eliminate rattles inside the boat:
- Tightening loose aluminum boat parts, applying caulking to trim, etc.
- Securing loose items in the boat, such as the oarlock horns.
But I want to limit the vibrations that get transferred from the motor to the boat in the first place.
What can I do to reduce the vibrations? The motor is brand new, so it shouldn't have any mechanical issues causing extra vibrations.
Photos:
