Not sure how much this is a legal question but part of it is technical.
I have a car with a completely out of service ABS system as the technician claims (many erorrs in the control system). This is why the biannual inspection can't be passed - this car is no more allowed for use. (Germany)
My question is: afaik ABS itself is an option in terms there are old cars without it and still allowed for use (Clearly, ABS is great to reduce risks). Then, is it possible to "disable"/"remove" ABS? or is this component too deeply integrated?
    Generally speaking, the rule in Europe is that if a safety feature was fitted to the vehicle when new, then it must exist and pass inspection. I can't speak for the specifics of your case though.
    – Chenmunka
    Commented Mar 22, 2023 at 12:03
  • There aren’t really many components in an ABS system, so it shouldn’t be too difficult to identify what is wrong.
    – HandyHowie
    Commented Mar 22, 2023 at 17:14
  • they say it seems the control unit is damaged and will be quite expensive kfzteile24.de/magazin/werkstatt-service/… - EUR 600 to 1400
    – J. Doe
    Commented Mar 22, 2023 at 18:22
