What are the torque specs for a 95 Chevrolet S10 4.3 vortec with intake number 10172785?
It depends on the exact vehicle. The VIN will either have a W or a Z (I don't know which position this will be in, but I'm assuming it will be self evident). These values hold true for either the 94 or 95 S10 with the 4.3L Vortec engine. Here is the torque sequence for the intake:
The amount of torque, depending on the VIN are as follows:
VIN Z:
  • All except bolt A: 35 lb-ft
  • Bolt A: 41 lb-ft
VIN W:
  • Lower: 35 lb-ft
  • Upper: 10 lb-ft
NOTE: This information is pulled from a Haynes manual, including the image.
  • For "VIN W", do "upper" and "lower" refer to their orientation in the picture provided?
    – FreeMan
    Feb 22 at 17:53
  • @FreeMan - No, the image provided is for VIN Z. Feb 22 at 18:09
