My friend's car has recently started losing power upon accelerating. He took it to the garage to have it checked, but that got me wondering if the timing belt slippage could be a reason for that?
Cheers.
Cheers.
It's possible but extremely unlikely that the timing belt is the culprit to a power loss. The timing belt (or chain in some cases) synchronizes the movement of the pistons and valves in the engine. Most modern internal combustion engines are interference engines, meaning the piston at top dead center will hit any open valves, so a failure of the timing chain will usually result in catastrophic engine failure.
A power loss is far more likely to be fuel or ignition system related, there's far too many possibilities to list.
Transmission fluid is probably low, too. My son's 2013 Nissan Altima had no power after replacing the radiator, this past weekend. Thermostats, air filter also replaced. Cleaned multiple sensors and the pcv valve. Even threw in a cat cleaner. All that and the car wouldn't move while stepping on the gas. Turns out it had no transmission oil. Topped it off. Now, "it drives better then ever".
