I'm removing the engine from a 1999 Chevy Cavalier (2.2L bi-fuel). Step 28 in the service manual in Remove the transmission-to-engine support brace.
I've looked all around the transmission-engine connection and could not find anything that appears to hold the transmission the the engine aside from the 6 bolts directly connecting them. Where will I find this brace?
engine-transmission flywheel
engine-transmission rear
Addendum:
I tried adding the following to the answer, but lack edit rights.
@Ben located the bracket for me. The easiest access to the bolts is through the right wheel well using a 13mm socket and long extension.
transmission bolts
engine bolts
Removing the oil filter would likely make access even easier, but mine seems seized.
  • maybe it was removed at one point it should be on the under side bolted to the block and transmission I believe.
    – Ben
    Sep 26, 2016 at 12:12
I was wrong about the placement of the bracket. In some cars they have a bracket that goes from the bell housing to around the oil pan.
I believe in your second picture it's the bracket on the left hand side.
