I have a 2011 Chevy Cruze 1.8L
It starts fine when the engine is cold, however, after driving for a while then stopping it, it won't start. One day I drove it 25 km, stopped it, then tried to start it again, but when I applied the throttle the engine chokes and dies.
My only guess is the fuel system somewhere - maybe the fuel pump? Do you have any suggestions?
  • A little late , but What was your problem at the end? and the solution if you came up to a fix
    – CREM
    Commented Jul 24, 2020 at 13:43
It could be a clogged fuel filter, or a temperature sensor that has failed making the Air/Fuel Ratio too lean for restart on a "hot" engine.
